[Feature Request] Rotten Tomatoes Ratings for Movies
Thank you so much for continuing work on PHT. I really dislike the Plex Media Player layout.
Quick request, can RT ratings be added to movies?
Thanks!
The client support for it has been added to the latest RasPlex versions, so it’s only a matter of time before it’s also included in an OpenPHT release, since they are based on the same source code (except for platform dependencies).
However, the use of RT ratings is also dependent on using a very recent PMS version as well as specific configuration of the metadata agents. Apparently RT ratings only work with PMS if you give “Freebase” top priority in each agent list, both for the Freebase agent list and for the TMDB agent list. (I for one will never do that, as I consider Freebase to be less useful for my needs than TMDB.) In addition, some report that RT ratings will only be added for old content when making a full rescan from scratch of your entire movie library. (Apparently rescan for updates does not add RT ratings to old movies.)
Best regards: dlanor
