[Feature Request] Save Home/Hubs/Pinned Menu settings
Please create a clickable option to save/export your Home Hubs & side Library Menu Pins order/settings. This would allow importation of the saved setup to the new PMP if you needed to roll back, or start over.
We’ve all been there,… something goes wrong, have to uninstall the PMP, pick the server… and setup your pins and hub all over again. If you have an extensive libraries like myself, the re-set up would take awhile. With an import option added, the setup would be automatic. (after you pick your desired server)
Plex really needs to do this to improve its relationship with its Android user base. There have been so many crappy Android versions released and users are forever having to reconfigure their apps after uninstalling and going back to a previous “semi-working” version.
Yes, this implementation would make things so much easier…on/for all systems.
More folks should vote for this.
Yes, I also feel that it’s cumbersome to have to reset the sorting every time I reinstall or use a new device. The sidebar settings should be saved, so that when reinstalling the client or using a new device, it defaults to the user’s saved settings, rather than having to set it up again each time.
