[Feature Request] Selectable supported Audio codec for Android TV App (AC3/DTS)
Hey there,
in the Tizen Plex App i can select DTS playback or not. The same is possible in the Android App, but why not inside the Android TV App?
My Android TV (Philips 5PUS6581/12) doens’t supports DTS, but Plex doen’t transcode DTS to AC3.
The only option to handle that problem are the Profiles, but they are very hard to handle and i didn’t get it work.
It would be so easy, if there are the same Audio option like in the normal Android App.
After a year i recognize, that this has been implemented.
You have to change your audio passthrough in Plex to Optical, even if you are using HDMI. Than you can choose AC3 or DTS.
