[Feature Request] Server-side Airplay Audio Output
A request to enable music output to Airplay audio enabled devices (in my case Apple Airport Expresses to amps/speakers) directly from the Plex Media Server, which removes the requirement for the Plex App to remain connected to the local network whilst playing. This will enable similar functionality to Apple’s iTunes Remote app. This is not casting from devices to Airplay, which is what the iOS Plex app currently does via the Apple Control Centre (swiping up from the bottom of the screen and selecting Airplay output).
On the Plex Apps, have “Airplay Audio” as a device under “Choose a Player”, along with a sub-list of detected Airplay devices that can be selected. This means that other media can be played locally while the server continues to play music separately via Airplay.
Sync the audio stream between the selected Airplay devices for seamless audio between zones. Continue with Airplay volume control via the Plex app when Airplay selected as player.
If users want to cast direct from their Plex apps, then they remain with “this device” selected as the player and use control centre.
There are a lot of other feature requests for something like this. Search for one that has tandem play or tandem sessions or something like that in the title. It’s not restricted to airplay or iOS but for everyone that uses Plex itself. Probably a lot more likely to happen than something restricted to just this one device and OS.
I even found the request I was thinking of. Granted this is for movies and TV shows, but can work for music, too: https://forums.plex.tv/discussion/74937/popular-tandem-playback-to-several-clients
Yes, I would be very interested in Server Side airplay as well - Synology DS Audio does this, both DLNA and AirPlay and is very useful as it doesn’t tie up a client to keep the session connected.
Some time ago I started switching from IOS to android and I’m trying to find out how I’ll be able to continue using my old airplay audio enabled speakers with Plex on android. Directly streaming the audio from the PMS to the speaker would solve that problem. Alternatively AirPlay Audio support on android would be great.
Would love this feature!
