Either use the Windows 8 app or this thing.
https://forums.plex.tv/topic/115593-beta-plex-downloader-desktop-sync/
You'll probably want to use xbmc or something that will download metadata for playing what you download with it.
I have the same need, using two servers for the transcoding horsepower as the Synology doesn't have enough horsepower for all scenarios. So to be clear, for this case you'd want to sync just Metadata and not the actual data.
The more I thought about this, it would be better to specify a Master and slave servers. As complicated as that sounds, right now I have to know which Plex Server to use when I'm on the player device, and its effectively a duplicate. It would be better if I could have the synology be the 'only' server from the perspective of the players and it offloads to a slave server as necessary. This way tasks like Plex sync and the like could be offloaded, but you really dont get into the scenario where you then have multiple servers from the players perspective.
bk
+1
+1
Server syncing would be epic!
+1
+1 This would be so useful if I could sync between two PMS.
+1
+1
+1
+1
+1
+1
+1
+1
+1 from me
Hey guys, I have two servers (one at home and one with me at college because the one at college can’t escape the local network) and I’ve just been storing my media on OneDrive to keep both servers current with the media on them. The only problem is that this doesn’t update any metadata changes I might make such as posters or backgrounds. I considered installing Plex to OneDrive but I thought that might cause corruption if two things are trying to update the same database at the same time.
Thoughts?
It is 2016 with still no server sync support for plex pass subscribers. Is this feature viable? I would love to have it!
^^What he said. This would solve so many issue for me. A semifix that would work for me is to have the data replicated via a thirdpartsoftware and just make plex share the metadata.
