[Feature Request] sort movies by subtitles
Truly sorry if i opened the request in the wrong place/category,
but i did not found any feature, nor a request like that…
I used up until now, a little software called EMDB that had that feature,
that would simply show you what movies have that specific subtitle in a list(all my movies have external subtitles).
I switched to PLEX because a good friend of mine recommended it, and i am truly blown away.
but that little feature is painfully absent for my family.
it would be great to see it.
thank you very much,
Shlomi
try Plex2CSV
thank you for replying, but i was thinking more along the lines of adding - subtitles to the Filter function.
so that when i use the filter with the specific subtitles language , i can view only the movies that has those type of subtitles (English, Hebrew, etc…)
+1 need this feauture too !!! The posibility to filter, sort our movies or tv series by subtitle as we can do with genre etc. Buy the way thanks a lot for this beautyful and usefull app :slight_smile:
seems like it was implemented finally :smile:
