I don’t use ratings, but I do like to see the codec on the player screen.
I can only enable both, or none.
Would like to disable rating, and keep codec enabled. Seems like a minor adjustment to split this into two options you can enable/disable.
Just to clarify: this is about the player preferences?
Settings > Experience > Player > Show Codec and Rating
Exactly!
