While not a fan of the new UI by any means, I guess it’s functional. The only thing that I’m really missing is the ability to view only unwatched items. I can order the list by unplayed per category, per server, but a filter would be better.
I have the same problem/complaint. There is a filter called Unplayed - All, but it does nothing. In the old UI when viewing your shows as all, it showed every show in one large page without the season subfolder/categories. Further filtering that view by Unplayed allowed you to quickly access all the Unplayed shows in one view. This new UI does not do that. Very disappointed.
UPDATE:
Oh, I just figured my problem out, just not used to this new UI at all. I had to change my type from TV Shows to Episodes first, then my Unplayed filter works as I expected.
