we’ll see if we can allow that in the future, i used to browse my iTunes playlists by different types…
this is slightly tricky as a playlist can have between 1 and “all” artists from a library in it, so it’s not clear you could make a “reasonable” station where there are more than a few artists in it.
Super, thanks you for the reply and for your thoughts!
On the subject of a “playlist radio” - I wonder if you could use the relative proportion of artists in the playlist to weight the radio algorithm? Or are there other signals you can use - like the genre of tracks? And, I suppose, if the worst case is that you end up with “library radio”, that’s not very bad. Just thinking out loud…
By the way, my personal opinion is that the more surprising/less predicable the radios, the better.
