feature requests
hi here, just wanted to make a couple feature requests :slight_smile:
1 - add a Play Next Episode button to the TV shows page, so you don’t have to drill down into seasons and then scroll to the bottom of the list to play the next episode.
2 - Add a “Unwatched” filter for the TV Shows and Movies pages.
thanks :slight_smile:
  1. In the top right when you are viewing the episode information, there are next/previous buttons next to go home.
  2. The most recent version of the app has filters. When in the browse section for movies you can select unwatched. For TV if you change to episode view, unwatched can be filtered as well.
Basically your request have already been added unless I misunderstood you.
1 - okay, those arrows are cool, but they don’t save any time. A Play Next Episode button, an option that will play the first unwatched episode, will avoid having to drill down into the season, then episode list. Much faster way of watching new stuff! In fact, the play button should absolutely default to this Play Next Unwatched Episode option. It should be less effort to watch new stuff than watch old stuff.
2 - I haven’t checked movies, but I see no option for filters in episode view. I’m asking to have the option of filtering Unwatched at every level, from tv shows/movies downwards. Again, that would make finding new stuff much faster.
Thanks.
Okay, found the Unwatched option. I don’t really think “filters” is an accurate term - it’s more “sorting”. A filter would remove everything but what you select. Which is what I’d like - an Unwatched option that hides everything except things I haven’t watched yet.
