Fewer Actors are being shown in Cast
Server Version#: 1.25.3.5409
Player Version#: Plex Web Version 4.69.1
Ever since I switched to the new agent, there are fewer Actors listed under Cast in a lot of my TV Series.
Here is one example: Ascendance of a Bookworm
My server:
TVDB
https://thetvdb.com/series/ascendance-of-a-bookworm
TMDB
I can provide more examples if needed.
Plex Media Server Logs_2022-01-13_12-33-34.zip (11.5 KB)
Let me know if there are more logs I need to upload.
This is exactly the kind of reason I stopped using the new Plex agent. It has broken listings and no way to fix or switch over to a better database listing.
100% agree. Cast listing for TV series is the one major limitations the modern plex scanner/agent has.
You can even see here Ascendance of a Bookworm - Where to watch episodes online - Plex for this show its the same. I’ve been told that over time it’ll improve but I’ve not really noticed much since the new agent was rolled out.
Here are more examples:
Ones with Fewer Actors:
In addition, the new agent also sometimes has English dub actors instead of Japanese actors. The old agent only did Japanese actors like god intended.
Ones with Japanese Anime that list the dub English Actors:
The problem isn’t the new agent itself, there is something wrong with the new TV agent now.
I have a library I originally created with the new agent, and I got a good list of cast when I created it, but if I do a metadata refresh on a title now the cast row reduces to just 2-3 actors generally, and it had more while still using the new agent in the beginning.
I just did a couple screenshots using Princess Principal after making a snapshot of my dataset so I could roll back after doing this…
Cast row before:
Same cast row after refreshing metadata:
Here’s a fun one. I should mention I actually have two different anime libraries, one on the old agent and one on the new agent. So I can do a real apples-to-apples comparison.
His and Her Circumstances (Kare Kano)
Old (TVDB) metadata agent:
New Plex TV agent (as I found it just now):
After refreshing and metadata just now on the New Plex TV agent:
Bump
I recently added encodings of World End to my server…
Here’s the New Plex TV scanner’s cast list:
Unfortunately I had some issues getting a screen shot of the cast list on the old (theTVDB) metadata agent. So I had to resort to this… ( :smile: )
Why is the cast list on the new Plex Agent so low? It doesn’t even cover the main cast of the show. Let alone any supporting cast. The TMDB page I linked shows plenty more cast given, so this isn’t a case of theTVDB being more complete.
