File bot and Namins Schemes
My Foler Structure is currently this
Plex
Movies
Startrek orginal series collection
Startreck motion pciture MP4
Startrek 2 . mp4
Etc
I am currently using this expression Movies/{collection}/{plex.tail}
However I find that it puts some movies into collections when there is only one film.
How can i get file bot to name and do a file structure similar to below
Movies
Batman
Batman
Batman retunrs
Batman forever
Batman Dark Knight
Batman Begins
Dark night rises
TVDB Collections are setup for not only TV + Movies, but also for Movies with Intended Sequels. So it’s very common to have 1 movie in a collection if either of these is the case. For instance, Avatar currently only has 1 movie in the collection, but there are 4 other movies coming out between now and 2027 or something ridiculous like that. Or 2001: A Space Odyssey also includes 2010 : The Year we Made contact.
If you want the folder for the collections, leave it the way you have it. If you don’t want the folder for the collection, remove the {collection} tag.
Regardless of which you choose, Plex will still place them in collections if you have that option set in the Agent. It does not function off of the folder structure.
TL;DR: file naming and folder structure has no influence over collections inside Plex.
These are either fetched from TMDB by the Plex agent (can be switched off)
or
are read from the embedded meta tags of your mp4 files. If you have a video file.mp4 which has the ‘Album’ metatags populated, then Plex will put the video into a collection, named after the content of the Album metatag.
