File nameing
Hi There some of my plex movies are named correctly through file bot, however in the plex Movie database, i have some that show up in this format
CON_Air
DVD_Title
etc how to i get rid of the _ and force plex to use the names that are correctly assigned.
Sounds like you have enabled Local Media Assets for your library and prioritized it higher than let’s say Plex Movie / The Movie Database.
That’ll result in plex checking the file for embedded metadata (in particular titles).
Overall this should only happen with mp4/m4v files – still it can be helpful to change the agent priorities in Settings > Server > Agents > Movies and scan the library again.
Thanks What about collections. Some of my films are being picked up as collections and others arnt
This can be caused by 2 things:
Embedded Metadata
Same as with the title… if your agent settings favor Local Media Assets and your mp4/m4v files have embedded metadata, Plex will associate the Album tag (embedded metadata) as Collection in Plex.
Your Library configuration
If you have enabled Use collection info from The Movie Database in the library’s advanced settings this will automatically create collections for your movies — independent if you have other movies from that collection or not.
Ok When using file Bot would you use the plex naming standard binding or do a custom expression
