Filter by content rating "None" not working
Hello,
Running PMS 1.32.7.7571 for Windows. I have an outgoing account share that uses content rating filters, and all of them seem to function except for the “None” category. “None” is selected and appears in the filter list, however the account still is able to see movies with the content rating field set to None. Case matches, I’m at a loss.
Any suggestions?
This does seem to not be working. I just made a report for it. None means the Content Rating field is blank/empty.
For now the only real thing you can do is mass/bulk change all your server content with a blank rating to NR or Not Rated and use that as a the exclude rating restriction
Thank you for making the report! I searched earlier instances of the same issue and it appears that it may have been fixed in an earlier version update, but then slipped through again. I appreciate the explanation and the work around as well. Cheers!
