Can't filter for "no rating" any more
Server Version#: 1.23.1.4602
Player Version#: 4.57.4
I noticed that I can’t filter content for “no rating” any more. The UI changed at some point and now, the content list doesn’t update until one of the ratings (1-5) is selected. Before, I could filter for played (Unplayed == false) content with no rating to easily rate stuff I’ve watched recently.
You can use the Advanced filters with
Rating Is …
Notice the “Order by” selection.
This view doesn’t include any movie which already has a star rating.
It does for me, the filter doesn’t seem to have any effect until I select a specific star rating. And once I do, there is no way to un-set it. I’ve also tried this in the online web player and my server’s.
I’ve tested this. I only have very few star’red movies and they don’t appear in the list when I select the above parameters.
Try changing to “2 stars” and then back to “no stars” (by dragging the first star to the left). Watch the item count before and after.
You dismiss this filter by clicking on the white X, top-left.
Thanks, that did it, it needs to be actively set to “no stars” for the filter to take. I think this might be the only instance of anything requiring a swipe/drag motion in Plex? Though I imagine ratings on movies can also be reset this way.
Indeed, they can.
