I group selected about 10 movies to change their rating from “None” to set it to just a blank field as I wanted to let my NFO meta pick it up.
Now when I go to filter my lists, Content Rating just shows:
Unable to load options
Any thoughts? Nothing is in the Plex log.
I guess I have found the following in the log, although not lined up to the time of the filter request:
Line 258: Mar 22, 2018 22:50:01.689 [0x14bd287ff700] ERROR - Error issuing curl_easy_perform(handle): 56
Line 259: Mar 22, 2018 22:50:01.690 [0x14bd287ff700] WARN - HTTP error requesting GET http://10.10.1.1:8200/rootDesc.xml (0, No error) (Recv failure: Connection reset by peer)
Line 366: Mar 22, 2018 22:50:02.838 [0x14bd1a5f4700] ERROR - Sync: failed to get status for sync list 9357631, sync item 25490770
Line 368: Mar 22, 2018 22:50:02.838 [0x14bd1a5f4700] ERROR - Sync: failed to get status for sync list 9357631, sync item 25490774
Line 370: Mar 22, 2018 22:50:02.838 [0x14bd1a5f4700] ERROR - Sync: failed to get status for sync list 24029967, sync item 25631791
Line 372: Mar 22, 2018 22:50:02.838 [0x14bd1a5f4700] ERROR - Sync: failed to get status for sync list 9357631, sync item 25873743
Line 374: Mar 22, 2018 22:50:03.104 [0x14bd2a3fd700] ERROR - XML: namespace
Line 375: Mar 22, 2018 22:50:03.104 [0x14bd2a3fd700] ERROR - XML: error :
Line 376: Mar 22, 2018 22:50:03.104 [0x14bd2a3fd700] ERROR - XML: SHμπ
Line 377: Mar 22, 2018 22:50:03.104 [0x14bd2a3fd700] ERROR - XML: SHμπ
Line 379: Mar 22, 2018 22:50:03.104 [0x14bd2a3fd700] ERROR - XML: SHμπ
Line 12097: Mar 22, 2018 22:50:21.810 [0x14bd2a5fe700] DEBUG - NotificationStream: Removing because of error
Line 12400: Mar 22, 2018 22:50:37.278 [0x14bd25bff700] ERROR - Soci Exception handled: Null value fetched and no indicator defined.
Line 12414: Mar 22, 2018 22:50:39.851 [0x14bd2a7ff700] DEBUG - NotificationStream: Removing because of error
Did I bork my DB?
so restoring a backup DB fixed the issue…
