Currently, Plex’s filtering only allows selecting one option, which is not very convenient. I would like to have a filter menu like this:
Use the advanced filters for more than one filter argument.
Thanks!
Indeed, the “Advanced Filters” work well on the web and macOS app. However, I seem to have not found this option on iOS and tvOS. Additionally, the conditions like “AND, OR, NOT, Contains, Does Not Contain, Greater Than, Less Than” might not be very user-friendly for older individuals. My parents, who are older, find it inconvenient to specifically go to the second-level menu to find “Advanced Filters” and then navigate through the third-level menu to set filter conditions.
