Find out which movies are not showing in Plex?
Hi, i have 556 movies located in sorted folders, but plex only finds 435. Is there a somewhat easy way to find out which movies are missing or do i have to go through every single movie and search for it in Plex? :#
I’m running V.3.27.1 on WIN 10 Pro.
Kind Regards, Morten
You can look at the logs of Plex Media Scanner (after attempting to refresh the library). This should show which files Plex drops / ignores.
Settings > Server > Help > Download Logs
Thanks for your help, although the logs are like a jungle it’s still easier than going through everything manually. :smile:
