Fire Stick Live TV Source
Server Version#: 1.22.2.4282
Player Version#: Fire Stick 4K
Tuner Make/Model: HDHOMERUN 3 tuner
Guide/Lineup name: Comcast Greater Plymouth Area
Using XMLTV?: no
Channel number/Name: All
I have my Plex Live TV /DVR setup and working fine from the Fire Stick Plex App, no problems at all.
But Fire Stick 4k has a feature to allow you to add a live tv source to it’s own Live TV guide/Grid. In order to do this, it gives you the option to “Sync” a live tv source and Plex is one of those options. However when I select Plex, it does a “Scan” and does not find any channels. Question: Is there a plex setting to allow other sources to use Plex’s live tv/drv? I’m thinking I don’t have my plex server setup correctly, because why would the Fire Stick offer a Plex option as a live tv syncing source if it wasn’t mean to work. I’ve searched on the Fire Stick forums and here and couldn’t find any info. Could someone offer some guidance. Thanks much.
