Plex Media Server: 1.21.1.3830, Synology DS918+
Plex Client: 8.11.0.22186, Amazon FireTV 4K stick, connected to HDMI input on LG B7 OLED.
I’m seeing the same thing as @e_nmc. I also noticed that after the search, if you directly select a movie instead of the actor, the movie plays.
On Plex home screen, search for hems.
Select Chris Hemsworth from list of actors (List also includes Liam, Luke, & Taylor Hemsworth).
Select movie “12 Strong.”
The Plex client immediately restarts, returning to home page.
Movie plays.
Let movie play for ~30 seconds, press back key to return to pre-play screen. Plex client restarts, returning to home page (the restart after exiting playback did not always happen).
Client logs: (File removed)
It is not in the logs, but it is repeatable. I test things a couple of times to make sure I could reproduce the situation. I also tested searching for “Nimoy” (only one actor listed), and selected one of the Star Trek movies. The behavior is the same as when searching for “Hems.”
Plex Server - Netgear ReadyNas 314 running Version 1.21.1.3830
Plex Client - Standard Fire TV Stick Version 8.11.0.22186 Plex for Android (TV)
The client reboots not the Fire TV. I can replicate it every I search for many different actors & directors. If I try to open a movie or TV episode the Plex client will crash and reboot. But if I search for the name of the movie of TV show it will play just fine so it is not corrupted media.
