Firestick Bug after update
Server Version#: 1.32.5.7349
Player Version#: 9.29.1.3463 (1a71eb3)
when navigating every now and then the previous screen get overwritten by a new screen.
problem can always be replicated by going to a movie and scrolling to an actor and selecting the actor. a list of other movies they are in appears - then when you press back button the screen shows two screens at once overwriting each other. you need to then select a menu or change library view to refresh the screen correctly.
Which FireTV device are you using?
Firestick 4k Max
not life threatening or anything but thought I should report it anyway
