Firestick does not play any 4K content
Hi everyone,
This is really doing my head in, I can not ply any 4K content on my 4K firestick. I have tried so many options.
It comes up with the error Playback was not possible:not enough CPU for conversion of this.
I have turned off the new player, I have increased the quality for home streaming and remote streaming to original. I have turned off subtitles, I have disabled pass through and I have tried using it with a VPN oh and I have also tried rolling back to an older version of Plex. If anyone could shed any light that would be great!
This should be a good read for that context
Thanks for the reply, I don’t think it is my tv. My tv is smart and also has Plex installed directly. When I use the inbuilt app it works perfect, only when I am using the firestick does it have issues with 4K content
Can you post the mediainfo for a title that causes this error?
Hi, please see screen shot below
That looks okay so far, can you post an actual media info, though?
That’s under the three dots > Get Info on the pre-play screen:
Example:
Media
Duration 1:44:53
Bitrate 2423 kbps
Width 1280
Height 694
Aspect Ratio 1.85
Video Resolution 720p
Container MKV
Video Frame Rate 24p
Video Profile high
Overlay
Part
Duration 1:44:53
File Batman - The Movie (1966) [720p BluRay x264].mkv
Size 1.78 GB
Container MKV
Video Profile high
Codec H264
Bitrate 1975 kbps
Language English
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 23.976 fps
Height 694
Level 4.1
Profile high
Ref Frames 5
Scan Type progressive
Width 1280
Display Title 720p (H.264)
Extended Display Title 720p (H.264)
Codec AC3
Channels 6
Bitrate 448 kbps
Language English
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title English (AC3 5.1)
Extended Display Title English (AC3 5.1)
Codec SRT
Language English
Display Title English (SRT)
Extended Display Title English (SRT)
