First Episode showing as "Season 1"
Hi all, I am experiencing an issue where instead of showing the first episode it shows “Season 1”
Is there a way to disable this feature?
What platform are you on? That’s a new feature of the “new experience” apps which are only available on mobile (as far as Android is concerned) right now. Did you side load the app somehow?
At any rate, that can’t be disabled at this time.
I am seen this on Roku TV
You tagged the thread as Android TV. I’d recommend changing that so that the correct eyes see this.
Regardless of that, the season poster showing in the first slot cannot be changed at this time.
This is by design for New Experience: New "episode" at the front called "Show" - Is this intended? (for good or bad - I don’t like it but am getting used to it)
Sadly this can’t be turned off. Irritating, isn’t it?
I’m super confused as to what problem that tile is supposedly solving. I read the thread linked above and the “explanation” doesn’t make sense to me.
How does having a blank rectangle that references the season I am currently browsing help me?
Here’s the great thing. It doesn’t fix any problem. Or help in any way whatsoever. It just adds clutter to an already poorly thought out, badly functioning UI.
