Fix 2036 Date
I have a whole bunch of episodes with the date of 2036. This basically makes “Recent Releases Episodes” useless and very annoying.
I tried “refresh metadata” on the TV series and it didn’t work. Any suggestions? Running the latest version of plex (not beta).
Are they MP4 files and that date is embedded in metadata of file maybe? if so you can turn off Prefer local metadata in the advanced settings of library.
If it’s not in the metadata of the file, then it’s possible that something screwed up and the “date added” field in the Plex database populated with an impossible date. A Plex dance should fix the files to get the correct “current” date. Be aware that doing the dance will cause the files to appear to still be “recently added”, but they should not longer stick to the front of this list in front of other “new” files.
Someone in the past had this happen. They manually edited the “date added” field in the Plex database itself. Very scary sounding, but if you are proficient enough and willing to try, you can search for the topic. I’ll give the search a try myself, and edit this if I find the post.
Edit: Aha. The first post I found mentioned that Plex picks the date the files were “created” or “modified” (unsure which one) on the filesystem. So in Linux, he did a “touch” on the files to update the date of the files to be the present date, and Plex picked up the new date and fixed it on their end.
The following post seems to suggest that Plex respects the filesystem “date” when it pulls the file in, but then never updates that date afterwards. They used a SQL command to fix the dates, but it’s a bit over my head to interpret it. If you are SQL proficient, then consider reading this post:
If it’s Feb 7th 2036 it’s nothing in your file. This has been a bug for a long time
You have to uncheck this
3 dots next to the library → Manage Library → Edit → Advanced
Usually a refresh of the metadata for the show fixes it but I’ve had a few instances where I had to Plex dance the show for it to change
