Shows stuck in 'recently added'
Server Version#: 1.41.0.8992
Player Version#: 4.136.1
Found an issue, in Plex (also Tautulli to help T/S), but have 3 shows that in Plex they always show at the front in “recently added”. After checking Tautulli, these 3 shows show that they were “Added in 73 years”, while ones that are recently added show “Added 18 hours ago” etc. I went to the linux cli (all my PMS are on Debian 11) and saw those 3 shows had files that were somehow dated wrong, so I used Touch to fix all of them. But even after that they still show the same in Plex and Tautulli.
Has anyone else ran across this?
Changing the file date after adding them into Plex will change nothing in Plex.
You’ll need a full Plex Dance of the affected shows to fix this.
Make sure to only start Plex after ntp has successfully synced the date/time of that machine. If it has a CMOS battery, check its health and replace it if needed.
