Fix match for the entire library
Server Version#: 4.116.1
Player Version#: N/A
I would like to know if i can fix all my movies library again in another language.
First selected Spanish and I need to switch all the movies database/ library to English.
Any instructions for that? I can fix movie by movie, but is not a choice.
You edit the library itself and change the language on the “General” tab.
Then you might have to “Refresh Metadata” for the whole library.
Thanks so much for your help.
Regards from Barcelona (Spain)
