[FIXED AGAIN] Movie Chapter thumbnails are not generated
Bumping it…
“If you can’t generate chapter thumbnails, then just don’t generate any chapters at all.”
   - Plex Media Server 1.15.5.994
Huh ???
Was meant to appear as a quote from PMS 1.15.5.994 (since it isn’t generating chapters on new videos).
Added the post on the desktop, but didn’t look quite the same on the phone…
I’ll abandon the satire for now, but my cynicism/sarcasm is still in play.
Cynicism and sarcasm I can do, and now I see the point :grinning:
Cannot believe this was broken for a few versions, then it got RECENTLY fixed, and now it’s broken again. It’s actually a little embarrassing!
Come on guys!
@BigWheel… Any response?
Broken it for a second time in a month, and still no response?
sorry not sure why i did not see notification of being pinged.
can you please grab the logs after adding another media (I am assuming you have it set to create after adding)
Just got to bed @BigWheel, however it’s exactly the same problem as a few versions ago.
Analysis is not being initiated on adding new content.
As stated previously, I’ve already downgraded in order to have new content work correctly.
Therefore to provide logs, I’d have to install the broken version, add some content, grab the logs, uninstall and downgrade again.
Trust me… It’s definitely broken again.
Yes, as per earlier in my post…
Getting some shuteye. Will check in tomorrow for any updates.
Thanks, Andy.
Same issue here. A bunch of folks are reporting this issue.
Manual analysis doesn’t even generate chapters for me with 1.15.5.994, let alone thumbnails.
Indeed @bradbart948, chapters are entirely broken. Still waiting for some kind of a response…
I’m sorry I don’t have any eta on a fix.
would you mind grabbing the scanner logs after the next time you add a movie
Thanks for the response @BigWheel. Can we then officially class this as a bug?
Well…I knew it was a beta version so I guess there’s only so much grief I can give you.
It was already considered as a bug. Sorry if i did not make that clear.
Ok, thanks for the confirmation.
I’m on the opposite side of the country this week, so it may be a couple of days before I can get to it…
