Server Version: 1.24.4.5081 Server OS: Windows Server 2012 R2 Standard
I just love it when things go backwards! Makes you really feel like things are moving… Um, backwards!
In March 2019, this very same problem was reported, was then fixed after a few months, and now 2 and half years later, it seems to be happening again…
This has actually been broken for around 3 to 4 months, and I’m not sure which version introduced the regression, however I do know that I actually noticed it around May '21, and in August, I started to plough though all of my extras to figure out which ones have been effected.
That took some time, I can tell ya!!
Looking at my Updates folder, it could have been 1.23.2 to 1.23.3… or earlier!
Here are the points of interest…
Chapter thumbnails for the movie itself are successfully generated.
My settings are… Generate chapter thumbnails >as a scheduled task and when media is added.
Refreshing metadata does not correct the missing thumbnails.
Doing the “plex dance” does not correct the missing thumbnails.
This can be replicated each and every time I add new extras that have chapters.
I am using the “new” movie Agent. Upgraded a few months ago. Is that where the problem is?
The XML actually shows that the chapter thumbnails are missing, compared to the movie itself.
XML for the actual movie, clearly shows the thumbnails for the movie chapters…
I cannot reproduce this issue on my side. Could you add a new item with extras and scan it into your library, then grab your server logs and send them to me.
18.20… Moved into place, and Refreshed Metadata → Movie\Other\Test Extra with Chapters.mkv
18.21… Plex started generating chapter thumbnails for the movie itself.
18.22… Scan Library Files.
18.25… Gather logs.
Just checked again, and I can see that it has managed to create a thumb for the 1st chapter, which is also reflected in the XML, however the other 2 chapters still have no thumb and the XML showed no thumbs when I checked it before hand…
Okay, I misunderstood your issue. I thought you were saying extras where not generating thumbnails, but you’re saying it’s embedded chapters in the extra that aren’t getting thumbnails generated, gotcha!
I was actually a little confused how this could have been misunderstood, but then I re-read my thread title, and I guess that could have been it, so I’ve amended the title.
But indeed yes, it’s the Chapter Thumbnails for the extras that is not being created.
So just added some new extras, and the problem is still apparent. Current PMS version I am on is… 1.25.2.5319.
Would really appreciate some love here as I’ve got tons of extras that have been affected by this, and what makes it worse, is that I am also in the process of moving content to a different drive, and of course once I move the extras, it breaks the extras chapter thumbnails as each item gets a new Video ratingKey.
Yes I had a rant some weeks ago, but lets be honest here… It was justified!
It’s now 2 months since @drzoidberg33 last responded, and that’s just not how you keep customers happy!
