Server Version#: 1.15.2.793-782228f99-x86
Player Version#: 3.83.1
In my case i’ve got “Conversion failed. The transcoder exited due to an error.” and i am using WIndows 10. A tried uninstalling and re-installing many times.
I’ve Found Out the Problem (in my case): My problem began on Ocean’s Eight (2018) and it includes the Persian Sub-title. I replace with English one so the ERROR is starting… So i thought that it might be the SRT file and tried different kind of manipulate… Finally Leaving two or three lines of Original ‘Persian Sub-title’ untouched… and replacing the original Subs with English Subs after two or three lines… and scan my library two or three times… and the PROBLEM is SOLVED (in my case)
