Server Version#: 1.21.0.3616
Player Version#: N/A
Several MKV TV files are not being found by Plex, despite having the correct filenames (i.e. exactly the same as the previous episodes). Several files have failed - in fact, I think that it has stopped working from a couple of days ago.
Not sure if these are the right logs, but I would really appreciate any help!
Nov 30, 2020 19:04:29.369 [1248] INFO - Plex Media Server v1.21.0.3616-d87012962 - Microsoft PC x64 - build: windows-x86 windows - GMT 13:00
Nov 30, 2020 19:04:29.369 [1248] INFO - Windows version: 10.0 (Build 18363), language en-GB
Nov 30, 2020 19:04:29.369 [1248] INFO - 4 3691 MHz processor(s): Architecture=0, Level=6, Revision=15363 Processor Identifier=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
Nov 30, 2020 19:04:29.489 [8156] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Nov 30, 2020 19:04:33.543 [9600] INFO - Refreshing paths watched by LibraryUpdateManager
Nov 30, 2020 19:04:34.167 [9412] WARN - [Preferences] No update channels loaded, so showing the previously-selected channel, labelled âunknownâ since we donât really know the name.
Nov 30, 2020 19:04:34.340 [9644] INFO - AutoUpdate: no updates available
Nov 30, 2020 19:04:34.514 [10020] WARN - Unrecognized MediaProvider feature: continuewatching
Nov 30, 2020 19:04:34.621 [9640] WARN - Unrecognized MediaProvider feature: continuewatching
Nov 30, 2020 19:04:36.009 [7404] INFO - Notification: Scanning the âMoviesâ section -
Nov 30, 2020 19:04:36.020 [7404] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:04:36.020 [7404] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:04:36.023 [7404] INFO - Notification: Scanning the âMusicâ section -
Nov 30, 2020 19:04:36.023 [7404] WARN - Skipping refresh of music library because weâre signed out or offline.
Nov 30, 2020 19:04:36.025 [7404] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:04:36.036 [7404] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:04:36.036 [7404] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:04:36.037 [7404] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:04:40.105 [1580] WARN - Sync: sync list 24378736 belonging to user 1 (suavebugger) has died of old age, ignoring
Nov 30, 2020 19:04:40.105 [1580] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Nov 30, 2020 19:04:41.613 [9232] WARN - MyPlex: attempted a reachability check but weâre not yet mapped.
Nov 30, 2020 19:04:42.724 [9440] INFO - AutoUpdate: no updates available
Nov 30, 2020 19:04:43.931 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:43.931 [9788] WARN - QueryParser: Invalid field âpromotedâ found, ignoring.
Nov 30, 2020 19:04:43.934 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:43.934 [9788] WARN - QueryParser: Invalid field âpromotedâ found, ignoring.
Nov 30, 2020 19:04:43.939 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:43.939 [9788] WARN - QueryParser: Invalid field âpromotedâ found, ignoring.
Nov 30, 2020 19:04:44.236 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:44.246 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:44.258 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:44.375 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:44.380 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:44.387 [9788] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:44.735 [9440] INFO - [PlexRelay] Allocated port 4009 for remote forward to 127.0.0.1:32401
Nov 30, 2020 19:04:45.253 [9440] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:45.292 [9440] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:45.334 [9444] INFO - [PlexRelay] Allocated port 10769 for remote forward to 127.0.0.1:32401
Nov 30, 2020 19:04:45.359 [9440] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:04:45.374 [9436] INFO - [PlexRelay] Allocated port 31701 for remote forward to 127.0.0.1:32401
Nov 30, 2020 19:04:47.546 [10004] WARN - NAT: PMP, got an error: NATPMP_ERR_RECVFROM.
Nov 30, 2020 19:04:48.818 [9232] WARN - MyPlex: attempted a reachability check but weâre not yet mapped.
Nov 30, 2020 19:04:48.822 [9644] INFO - AutoUpdate: no updates available
Nov 30, 2020 19:04:48.976 [10016] WARN - NAT: PMP, got an error: NATPMP_ERR_RECVFROM.
Nov 30, 2020 19:04:51.602 [6292] ERROR - Unknown metadata type:
Nov 30, 2020 19:04:53.618 [0420] ERROR - Error issuing curl_easy_perform(handle): 7
Nov 30, 2020 19:04:53.618 [0420] WARN - HTTP error requesting GET https://192-168-1-65.00777fb7bbb147de932cdabe0bc34498.plex.direct:32400 (7, Couldnât connect to server) (Failed to connect to 192-168-1-65.00777fb7bbb147de932cdabe0bc34498.plex.direct port 32400: Connection refused)
Nov 30, 2020 19:04:54.565 [9276] INFO - [PlexRelay] Allocated port 26185 for remote forward to 127.0.0.1:32401
Nov 30, 2020 19:04:54.620 [11776] ERROR - Error issuing curl_easy_perform(handle): 7
Nov 30, 2020 19:04:54.620 [11776] WARN - HTTP error requesting GET https://192-168-1-64.b80f4c489a894f6491999b3c944fa996.plex.direct:32400 (7, Couldnât connect to server) (Failed to connect to 192-168-1-64.b80f4c489a894f6491999b3c944fa996.plex.direct port 32400: Connection refused)
Nov 30, 2020 19:04:56.416 [4072] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 30, 2020 19:04:59.623 [9752] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 30, 2020 19:04:59.623 [7588] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 30, 2020 19:05:01.414 [8020] WARN - Connection Tester: Error testing media server Behemoth in 10000 ms.
Nov 30, 2020 19:05:02.152 [10020] WARN - NAT: PMP, got an error: NATPMP_ERR_RECVFROM.
Nov 30, 2020 19:05:03.653 [9788] INFO - AutoUpdate: no updates available
Nov 30, 2020 19:05:04.622 [6292] WARN - Connection Tester: Error testing media server Ed Moore laptop in 10001 ms.
Nov 30, 2020 19:05:04.774 [9640] ERROR - Unknown metadata type:
Nov 30, 2020 19:05:06.764 [9640] ERROR - Error issuing curl_easy_perform(handle): 3
Nov 30, 2020 19:05:06.764 [9640] WARN - HTTP error requesting GET /media/providers (3, URL using bad/illegal format or missing URL) ()
Nov 30, 2020 19:05:06.765 [9640] ERROR - Error issuing curl_easy_perform(handle): 3
Nov 30, 2020 19:05:06.765 [9640] WARN - HTTP error requesting GET /media/providers (3, URL using bad/illegal format or missing URL) ()
Nov 30, 2020 19:05:07.292 [9412] INFO - AutoUpdate: no updates available
Nov 30, 2020 19:05:12.782 [9424] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:05:17.440 [10048] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:05:17.446 [10048] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:05:17.446 [10048] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:05:17.447 [10048] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:05:17.565 [11376] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:05:17.604 [9424] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:05:17.627 [9412] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:06:04.103 [10012] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TV\The Voice\Season 19â/The Voice (US) - S19E10 - The Knockouts, Part 2 WEBDL-480p.xmlâ
Nov 30, 2020 19:06:14.956 [2692] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TVâ/sync.ffs_lockâ
Nov 30, 2020 19:07:29.309 [9552] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:07:29.310 [2368] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:07:29.314 [2368] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:07:29.324 [2368] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:07:35.236 [9576] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:07:43.343 [6540] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:07:43.347 [6540] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:07:43.347 [6540] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:07:43.348 [6540] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:07:43.402 [9552] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:07:43.461 [9664] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:07:43.504 [9308] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:07:43.709 [9664] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:07:49.805 [10816] WARN - SLOW QUERY: It took 203.125000 ms to retrieve 6 items.
Nov 30, 2020 19:08:10.373 [9232] ERROR - Couldnât delete the file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zip4973a59e-a5d8-4f76-8a5a-0616e24ef7faâ: The process cannot access the file because it is being used by another process
Nov 30, 2020 19:08:10.373 [9232] WARN - Could not delete file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zip4973a59e-a5d8-4f76-8a5a-0616e24ef7faâ after connection reset
Nov 30, 2020 19:08:12.531 [10000] ERROR - Couldnât delete the file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zipf5b9a611-b989-4d6c-8971-e264e77a2961â: The process cannot access the file because it is being used by another process
Nov 30, 2020 19:08:12.531 [10000] WARN - Could not delete file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zipf5b9a611-b989-4d6c-8971-e264e77a2961â after connection reset
Nov 30, 2020 19:08:22.101 [7124] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:08:22.108 [7124] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:08:22.108 [7124] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:08:22.109 [7124] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:08:22.155 [9308] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:08:22.347 [8396] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:08:22.467 [8916] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:08:38.453 [4304] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:08:38.464 [4304] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:08:38.464 [4304] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:08:38.466 [4304] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:08:38.494 [8396] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:08:38.526 [11780] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:08:38.609 [9264] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:08:38.805 [8396] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:10:05.085 [11100] WARN - SLOW QUERY: It took 250.000000 ms to retrieve 30 items.
Nov 30, 2020 19:10:32.526 [12108] ERROR - [Transcode] ClientProfileExtra: missing protocol parameter
Nov 30, 2020 19:10:32.526 [12108] WARN - [Transcode] ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=ac3)
Nov 30, 2020 19:10:32.526 [12108] WARN - [Transcode] ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=eac3)
Nov 30, 2020 19:10:32.526 [12108] WARN - [Transcode] ClientProfileExtra: ignoring directive: append-transcode-target-audio-codec(type=videoProfile&context=streaming&audioCodec=dca)
Nov 30, 2020 19:10:32.526 [12108] WARN - [Transcode] ClientProfileExtra: ignoring directive: append-transcode-target-codec(type=videoProfile&context=streaming&videoCodec=vp9)
Nov 30, 2020 19:10:32.526 [12108] WARN - [Transcode] TranscodeUniversalRequest: at least one profile extra directive could not be read
Nov 30, 2020 19:17:43.810 [9232] ERROR - Couldnât delete the file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zip32741688-db3d-43ad-af97-b1e3d12eabc4â: The process cannot access the file because it is being used by another process
Nov 30, 2020 19:17:43.810 [9232] WARN - Could not delete file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zip32741688-db3d-43ad-af97-b1e3d12eabc4â after connection reset
Nov 30, 2020 19:18:20.647 [9000] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TV\The Voice\Season 19â/The Voice (US) - S19E10 - The Knockouts - Part 2 720p.mkvâ
Nov 30, 2020 19:18:30.362 [1344] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TVâ/sync.ffs_lockâ
Nov 30, 2020 19:18:38.560 [9232] ERROR - Couldnât delete the file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zipc23ba1fb-38e5-4da9-ae01-6881558e8d40â: The process cannot access the file because it is being used by another process
Nov 30, 2020 19:18:38.560 [9232] WARN - Could not delete file âC:\Users\DAVIDR~1\AppData\Local\Temp\logs.zipc23ba1fb-38e5-4da9-ae01-6881558e8d40â after connection reset
Nov 30, 2020 19:19:20.650 [9152] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:19:20.662 [9152] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:19:20.662 [9152] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:19:20.664 [9152] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:19:20.728 [11668] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:20.750 [1928] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:20.871 [6696] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:21.096 [6696] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:34.628 [7588] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:19:34.648 [7588] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:19:34.655 [10416] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:19:34.670 [7588] WARN - QueryParser: Invalid field âcontentDirectoryIDâ found, ignoring.
Nov 30, 2020 19:19:41.831 [9552] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:19:41.835 [9552] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:19:41.835 [9552] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:19:41.836 [9552] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:19:41.888 [10416] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:41.891 [12228] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:41.974 [10104] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:42.228 [10416] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:19:45.605 [1816] WARN - Unable to load episode file [âseasons\19\episodes\11.xmlâ]
Nov 30, 2020 19:20:43.949 [9000] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TV\The Jonathan Ross Show\Season 14â/The Jonathan Ross Show - S14E04 - Colin Farrell, Danny DeVito, Jimmy Carr, Nicola Adams, Lolly Adefope, Lewis Capaldi WEBDL-1080p.mkvâ
Nov 30, 2020 19:20:51.911 [9000] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TV\The Jonathan Ross Show\Season 15â/The Jonathan Ross Show - S15E02 - Sean Bean, Michelle Keegan, Rose Matafeo, Liam Gallagher HDTV-720p.mkvâ
Nov 30, 2020 19:21:03.338 [6360] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TVâ/sync.ffs_lockâ
Nov 30, 2020 19:21:49.454 [10928] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TV\The Jonathan Ross Show\Season 12â/â
Nov 30, 2020 19:21:49.488 [10928] INFO - Library section 7 (TV Shows) will be updated because of a change in ââD:\TV\The Jonathan Ross Showâ/â
Nov 30, 2020 19:22:04.306 [11976] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:22:04.309 [11976] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:22:04.309 [11976] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:22:04.311 [11976] INFO - Notification: Scanning the âTV Showsâ section -
Nov 30, 2020 19:22:04.315 [11976] ERROR - JobRunner: exec of C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe failed: error 0xd8.
Nov 30, 2020 19:22:04.315 [11976] ERROR - Failed to start library section refresh job
Nov 30, 2020 19:22:04.316 [11976] INFO - Notification: Library scan complete - Extra information may still be downloading from the Internet
Nov 30, 2020 19:22:04.349 [10416] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:22:04.391 [8180] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:22:04.434 [11536] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:22:04.655 [10416] ERROR - Unknown metadata type: folder
Nov 30, 2020 19:22:04.678 [11608] ERROR - Unknown metadata type: folder
