Fixing Cover Photo
Does Anyone Know how to fix these or even know where it gets the cover photo from?
I’m going to assume it’s probably embedded in the files meta data. Easy enough fix just find the image you want to use and change it in the series edit > poster image (the little pencil you see when you hover over the series or season graphics bottom left) I found a few here.
