yopman
1
Cover problem:
- i add a serie, with using personal cover (poster.jpg) in every season folder, and one into the serie itself
- then, plex use the first cover i put for ALL seasons, even if i have poster.jpg in every folder.
Can you fix that ? - you can take 5 years like you do with other major problem.
It’s not broken. For season posters you need to use seasonXX.jpg as described at https://support.plex.tv/articles/200220717-local-media-assets-tv-shows/#toc-2
yopman
4
i not remember where i saw to put “poster.jpg” in every folder, seems to have work in past.
So thank you, it work now!
