All my music are in FLAC format on my Synology NAS, and I can't play it using the Trailers app (PlexConnect). How can I fix it?
It's not a good idea to use PlexConnect for music. Personally I use DS Audio (a Syno package) which is much more powerfull for music. All my music is converted to ALAC, not FLAC, so I have no problems, even with PlexConnect. You need to check if DS Audio can transcode FLAC to ALAC or not, otherwise I see no easy solution other then using a program to convert your library from FLAC to ALAC (or MP3).
Edit: I'm wondering if WAV is preferrabe to FLAC/ALAC. At least we would get rid off playing incompatibilites...
MP3 works fine with PlexConnect, but come on, MP3 sucks. Uncompressed WAV is very good.
I know about DS Audio but I installed PlexConnect in order to not need my iPhone/iPad bridging my videos/musics to the ATV, I want it directly from my NAS.
Using iTunes Server from Synology I can stream every music I throw at it, but unfortunately it only works on iTunes...
Music support on PlexConnect is experimental to say the least and isn't currently that high up on the priorities i am afraid; there were a number of issues that Roidy was working against that we do not know if they will ever get solved.
Hum.. I got it now, too bad! :(
Interesting request though. The main issue here is that we never even cared to request a PMS transcoding job on audio only.
Look in PlexAPI.py: You will find...
getTranscodeVideoPath vs getDirectVideoPath
getTranscodeImagePath vs getDirectImagePath
but only getDirectAudioPath... nothing about Transcode.
I guess it could/should (?) get implemented, but we really didn't spend that much time on audio support - other than proving the basic function.
DS Audio does not bridges music through iPhone/iPad. It only needs iPhone/iPad for the selection process.
My option is to play music on the A/V receiver. I do not even bother to switch-on the TV in such occasions. I pick the iPad (or Android phone), select the album (or playlist), and the NAS streams automatically to the ATV, and the ATV (via optical cable) to the A/V receiver, no need to have the iPad / phone /TV connected during music play.
FLAC/ALAC were made for hi-fi equipments, not for TV's, frankly I do not think that PlexConnect needs to invest too much on this area. The TV is a "natural source" to select films (or music shows), but in my opinion not a "natural source" to select music.
I know FLAC isn't good for TV, I do have audiophile grade phones but sometimes I just don't want to wear them, and prefer to use the ATV and see the albums and select precisely what I want with the nice interface, not just forward and backward.DS Audio does not bridges music through iPhone/iPad. It only needs iPhone/iPad for the selection process.
iPhone 5S | Tapatalk Pro
