Folder view on Rasplex, or filter unwatched
Hi guys,
Loving the work you’re doing with Rasplex, just got my second pi, so I can serve another tv.
One thing I was wondering, is there anyway you can either view by folder, or filter unwatched movies? (that would achieve the same thing for me as I have a ‘new’ subfolder in my library.)
Thanks,
Dom
Go into your movie library, tap Left until the ‘filter and sort menu’ slides in.
There is your ‘unwatched’ filter.
Excellent thanks!
