Seeing movies marked as "watched"
My rasplex seem to only show me movies that are marked as unwatched.  Is there any way to toggle this so that it will show me all movies when browsing, searching, and filtering.
Are you sure you're not accidentally filtering via the "Unwatched" category? What version are you on?
I am definitely not browsing through the "unwatched" category.  I can browse that category too, but the results are the same.  The entire movie section filters and only displays unwatched shows no matter what I do.  It even behaves this way for searches.  Is it supposed to do that?  If so, is there a toggle or a config file I can tweak?
I believe I am on the latest and greatest version (0.3.1).  Although I am not sure where to find that version number in the UI.  Auto update is on.
Update:  I am definitely on 0.3.1.
Is anyone else having this issue?  I can't be the only one.
