Library sorting feature request (hide watched options)
Can you add a hide watched option to this screen?
I usually watch by pressing the play button randomly. However, it also replays the movies I watched. I want to prevent this.
There should be an Unwatchedor Unplayed option at the top of the filter menu which you can use along with the other genre filter you have applied in that menu. Im not sure which app you are using but my screenshot is from Android TV. Other TV based apps should be the same.
Plex_20231205_171312
