Is it possible to force PMS to transcode a file to 5.1 AC3 instead of 5.1 AAC via OPHT?
Not exactly.
In Preferences > System > Audio Output
Enable Passthrough
Enable Dolby Digital (AC3) Capable receiver
Enable Dolby Digital (AC3) transcoding
@benjaminwolf said:
Not exactly.In Preferences > System > Audio Output
I can’t find this last point.
you have to set the channel output to 2.0 to have it appear under the ‘enable Dolby Digital…’ Option.
Now that this happened: https://ac3freedomday.org/
They might be able to use a better transcoder. But its probably limited to 2.0 because of (old) licensing reasons.
I wonder if you could write your own profile to do it somehow (on the server side)?
@plexbox.us said:
Now that this happened: https://ac3freedomday.org/They might be able to use a better transcoder. But its probably limited to 2.0 because of (old) licensing reasons.
https://forums.plex.tv/discussion/73702/writing-profiles-for-dlna-devices
Thanks for the responses. Not a huge deal. Was just playing with it and for a specific reason trying to force 5.1 ac3 (instead of aac–>pcm) output. Life goes on.
