Force audio setup settings
Server Version#: 1.51.1.4020
Player Version#: 1.32.8.7639
Is it possible to set the audio settings fixed via ini file so that they remain constant and never change? I Quite ofte have to change back to my own settings as the Plex HTPC resets the audio settings after a fresh start. See photo attachment how I want it to be set in ini-file.
This problem occurs every time i restart my pc which is scheduled every night.
Same problèm here
Happens for me every time I have to update. But it happens at other times too.
Has anyone tried setting those parameters through the mpv.conf? Maybe that works…
Yes and it didn’t work at all for me, that’s why I have two mpv configs. One for mpv with audio config and the other for Plex without.
I was also having the problem of audio settings dropping (Plex HTPC audio settings reset every update - #46 by alphafoxtrot). Several users and I eventually figured out that it was tied to graphics driver updates. This was supposedly fixed in v1.41.0 (Plex HTPC for Mac, Windows, and Linux - #44 by Moussa). If your setup still has audio settings reset, it’s something @Moussa might want to know about.
