For some reason Plex is not showing the proper HDMI device for me to use my AVR until I have manually forced it to connect (Opening audio control panel or using something like aplay)
I have HDMI Nvidia #0,2,3
The device I need is Nvidia #1 which only shows up for me AFTER it's been used by something else, then says Onkyo HT-R390 Nvidia #1
I've no problem setting this up like that once, but it does not remember it at all, disappears when I restart and it shows only #0,2 & 3 again
Any one had this issue before? Any recommendations? Any way I could just make ALSA (Bypassing pulse due to that playback speed problem) remap the device to 0,2 or 3?
Edit:
Been doing some more digging. Now I've got the right terms down (I hope)
I've got 4 codecs in my /proc/asound/NVidia folder
Codec#0/1/2/3
Looking at the information in the files, the codec I need to use is codec#1
In Plex the audio settings are set to HDMI in the standard options and in the advanced options, I only see codecs#0,2+3 until I have manually 'activated' codec#1
If I make something use codec#1 and then go into the settings, I can select the right output device and it all works perfectly.
Anyone know how to allow Plex to show codec#1 all the time? It currently loses the setting on restart and has to be set back once I have 'activated' codec#1
