Forced Connection Closure - Win7
In theory both should work but you might as well see what happens.
Also make sure that you do not just swap out the settings.py file, the format and contents of it have been changed.
Ok I will give it a go. Was happening at least 3 times a day before.
I'll give it a day with the same config then swap if it does it. I manually reconfigured as it's simple anyway.
Thanks for your help.
