Trailers is unavailable win 8.1 ATV 3
ATV: 5.2.1
ATV IP DHCP 192.168.1.5 wifi
IP PMS: 192.168.1.17
IP Plexconnect: 192.168.1.17
IP Router: 192.168.1.1
Everything else is working on the ATV. Logon to Netflix works, buying things on Apple movies works.
Settings:
'enable_plexgdm'  :True', 'False'), \
    'ip_pms'          :'192.168.1.17',), \
    'port_pms'        :'32400',), \
    'enable_dnsserver':'True', 'False'), \
    'port_dnsserver'  :'53',), \
    'ip_dnsmaster'    :'8.8.8.8',), \
    'prevent_atv_update'           :'True', 'False'), \
    'enable_plexconnect_autodetect':('True', 'False'), \
    'ip_plexconnect'  :'192.168.1.1',), \
    'hosttointercept' :'trailers.apple.com',), \
    'port_webserver'  :'80',), \
    'enable_webserver_ssl'         :'True', 'False'), \
    'port_ssl'        :'443',), \
    'certfile'        :'./assets/certificates/trailers.pem',), \
    'loglevel'        :'Normal', 'High', 'Off'), \
    'logpath'         :'.',), \
Following this guide:
What made my head in was this:
Enter the IP of your PlexConnect server as the DNS.
  • Find your PlexConnect IP from the terminal/CMD window.
  • Then set the AppleTV's DNS to the PlexConnect IP.
DNS on ATV is set to 192.168.1.17
Apple TV DNS was originally 192.168.1.1 (same as gateway/router)
Should i set the plexconnect IP manually to 192.168.1.1 in the settings.py as i have done above? Cause the guide kind of hints to that i should do that. Guide is very unclear unfortunatly. (hint, please change it)
Log from Plexconnect window:
22:05:30 PlexConnect: ***
22:05:30 PlexConnect: PlexConnect
22:05:30 PlexConnect: Press CTRL-C to shut down.
22:05:30 PlexConnect: started: 22:05:30
22:05:30 PlexConnect: IP_self: 192.168.1.17
22:05:30 DNSServer: started: 22:05:30
22:05:30 DNSServer: ***
22:05:30 DNSServer: DNSServer: Serving DNS on 192.168.1.17 port 53.
22:05:30 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.
22:05:30 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.co
.apple.com.edgesuite.net'] => 127.0.0.1
22:05:30 DNSServer: forward other to higher level DNS: 8.8.8.8
22:05:30 WebServer: started: 22:05:30
22:05:30 WebServer: ***
22:05:30 WebServer: WebServer: Serving HTTP on 192.168.1.17 port 80
22:05:30 WebServer: WebServer: Serving HTTPS on 192.168.1.17 port 4
22:06:50 DNSServer: DNS request received!
22:06:50 DNSServer: Source: ('192.168.1.5', 53457)
22:06:50 DNSServer: Domain: trailers.apple.com
22:06:50 DNSServer: ***intercept request
22:06:50 DNSServer: -> DNS response: 192.168.1.17
22:06:52 DNSServer: DNS request received!
22:06:52 DNSServer: Source: ('192.168.1.5', 56209)
22:06:52 DNSServer: Domain: ax.init-cdn.itunes.apple.com.akadns.net
22:06:52 DNSServer: ***forward request
22:06:52 DNSServer: -> DNS response from higher level
22:06:52 DNSServer: Source: ('192.168.1.5', 52709)
22:06:52 DNSServer: Domain: p45-buy.itunes.apple.com.akadns.net
22:07:34 DNSServer: DNS request received!
22:07:34 DNSServer: Source: ('192.168.1.5', 56941)
22:07:34 DNSServer: Domain: mesu.apple.com
22:07:34 DNSServer: ***restrain request
22:07:34 DNSServer: -> DNS response: 192.168.1.17
22:07:34 DNSServer: Source: ('192.168.1.5', 60579)
22:07:34 DNSServer: Domain: ax.init.itunes.apple.com
22:07:34 DNSServer: ***forward request
22:07:34 DNSServer: -> DNS response from higher level
22:07:35 DNSServer: DNS request received!
22:07:35 DNSServer: Source: ('192.168.1.5', 63654)
22:07:35 DNSServer: Domain: itunes.apple.com
22:07:35 DNSServer: ***forward request
22:07:35 DNSServer: -> DNS response from higher level
22:07:36 DNSServer: DNS request received!
22:07:36 DNSServer: Source: ('192.168.1.5', 59820)
22:07:36 DNSServer: Domain: p45-buy.itunes.apple.com
22:07:36 DNSServer: ***forward request
22:07:36 DNSServer: -> DNS response from higher level
22:07:38 DNSServer: DNS request received!
22:07:38 DNSServer: Source: ('192.168.1.5', 51115)
22:07:38 DNSServer: Domain: configuration.apple.com
22:07:38 DNSServer: ***forward request
22:07:38 DNSServer: -> DNS response from higher level
22:07:39 DNSServer: DNS request received!
22:07:39 DNSServer: Source: ('192.168.1.5', 64307)
22:07:39 DNSServer: Domain: a5.mzstatic.com
22:07:39 DNSServer: ***forward request
22:07:39 DNSServer: -> DNS response from higher level
22:07:40 DNSServer: DNS request received!
22:07:40 DNSServer: Source: ('192.168.1.5', 62405)
22:07:40 DNSServer: Domain: a4.mzstatic.com
22:07:40 DNSServer: ***forward request
22:07:40 DNSServer: -> DNS response from higher level
22:07:40 DNSServer: Source: ('192.168.1.5', 63907)
22:07:40 DNSServer: Domain: a1.mzstatic.com
22:07:40 DNSServer: Source: ('192.168.1.5', 49776)
22:07:40 DNSServer: Domain: a2.mzstatic.com
22:07:40 DNSServer: Source: ('192.168.1.5', 63240)
22:07:40 DNSServer: Domain: a3.mzstatic.com
22:07:41 DNSServer: -> DNS response from higher level
22:07:43 DNSServer: DNS request received!
22:07:43 DNSServer: Source: ('192.168.1.5', 56913)
22:07:43 DNSServer: Domain: init.itunes.apple.com
22:07:43 DNSServer: ***forward request
22:07:43 DNSServer: -> DNS response from higher level
22:07:44 DNSServer: DNS request received!
22:07:44 DNSServer: Source: ('192.168.1.5', 65294)
22:07:44 DNSServer: Domain: play.itunes.apple.com
22:07:44 DNSServer: ***forward request
22:07:44 DNSServer: -> DNS response from higher level
22:07:45 DNSServer: DNS request received!
22:07:45 DNSServer: Source: ('192.168.1.5', 64481)
22:07:45 DNSServer: Domain: pd-st.itunes.apple.com
22:07:45 DNSServer: ***forward request
22:07:45 DNSServer: -> DNS response from higher level
22:07:46 DNSServer: DNS request received!
22:07:46 DNSServer: Source: ('192.168.1.5', 52946)
22:07:46 DNSServer: Domain: trailers.apple.com
22:07:46 DNSServer: ***intercept request
22:07:46 DNSServer: -> DNS response: 192.168.1.17
22:07:47 DNSServer: DNS request received!
22:07:47 DNSServer: Source: ('192.168.1.5', 51436)
22:07:47 DNSServer: Domain: init-p01st.push.apple.com
22:07:47 DNSServer: ***forward request
22:07:48 DNSServer: -> DNS response from higher level
22:07:48 DNSServer: DNS request received!
22:07:48 DNSServer: Source: ('192.168.1.5', 62642)
22:07:48 DNSServer: Domain: 5-courier.push.apple.com
22:07:48 DNSServer: ***forward request
22:08:19 DNSServer: DNS request received!
22:08:19 DNSServer: Source: ('192.168.1.5', 49378)
22:08:19 DNSServer: Domain: data.iana.org
22:08:19 DNSServer: ***forward request
22:08:19 DNSServer: -> DNS response from higher level
22:09:07 DNSServer: DNS request received!
22:09:07 DNSServer: Source: ('192.168.1.5', 51163)
22:09:07 DNSServer: Domain: e673.g.akamaiedge.net
22:09:07 DNSServer: ***forward request
22:09:07 DNSServer: -> DNS response from higher level
22:09:07 DNSServer: Source: ('192.168.1.5', 60507)
22:09:07 DNSServer: Domain: se.itunes.apple.com
22:11:36 DNSServer: DNS request received!
22:11:36 DNSServer: Source: ('192.168.1.5', 55681)
22:11:36 DNSServer: Domain: bookkeeper.itunes.apple.com
22:11:36 DNSServer: ***forward request
22:11:36 DNSServer: -> DNS response from higher level
22:11:37 DNSServer: DNS request received!
22:11:37 DNSServer: Source: ('192.168.1.5', 60218)
22:11:37 DNSServer: Domain: upp.itunes.apple.com
22:11:37 DNSServer: ***forward request
22:11:37 DNSServer: -> DNS response from higher level
22:12:35 DNSServer: DNS request received!
22:12:35 DNSServer: Source: ('192.168.1.5', 62602)
22:12:35 DNSServer: Domain: mesu.apple.com
22:12:35 DNSServer: ***restrain request
22:12:35 DNSServer: -> DNS response: 192.168.1.17
I can't see any problems in that log, but still get the trailers unavailable message.
Am i supposed to change something on the plex media server?
No changing settings.py, please.
You dont want me to change anything at all there? Only change things on the apple tv itself?
Yes. No changes to PY code needed. PlexConnect - when first run - will create a Settings.cfg file. You might edit that... but for a std. setup there shouldn't be a need to it either.
As long as you have "enable-plexconnect_autodetect"=True, "ip_plexconnect" is not used. I guess.
You did work through the "certs" part, right?
Yes, i have reinstalled it all 3 times now and dont touch anything. Still trailers unavailable.
23:51:16 PlexConnect: ***
23:51:16 PlexConnect: PlexConnect
23:51:16 PlexConnect: Press CTRL-C to shut down.
23:51:16 PlexConnect: started: 23:51:16
23:51:16 PlexConnect: IP_self: 192.168.1.17
23:51:16 DNSServer: started: 23:51:16
23:51:16 DNSServer: ***
23:51:16 DNSServer: DNSServer: Serving DNS on 192.168.1.17 port 53.
23:51:16 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.17
23:51:16 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
23:51:16 DNSServer: forward other to higher level DNS: 8.8.8.8
23:51:16 WebServer: started: 23:51:16
23:51:16 WebServer: ***
23:51:16 WebServer: WebServer: Serving HTTP on 192.168.1.17 port 80.
23:51:17 WebServer: started: 23:51:17
23:51:17 WebServer: ***
23:51:17 WebServer: WebServer: Serving HTTPS on 192.168.1.17 port 443.
But it doesn't seem to find the actual PMS though? PMS is up and running, i can play from a smart blu ray, from an ipad or a pc or an android.
The log reacts when i move around on the appletv, says request from Netflix etc so the connection must be fine.
You have to point your aTV DNS to the PlexConnect host, though. In this log snippet, no DNS request was captured.
The PMS is looked for when entering trailers app - once it is needed. No before.
Plexconnect host is/means the same ip as the PMS, correct? They are on the same computer. In this case 192.168.1.17
It is not necessarily on the same machine - in your case it might be...
Did you set your aTV DNS setting to this address? Did you hit the trailers icon already?
