Server Version#: 1.42.2.10156
Player Version#: 4.157.0
I’m encountering a strange playback issue when casting FLAC music from Plexamp/Plex Web to a JBL Authentics 200 (Google Cast) using my Plex Media Server running on a NUC (Docker — Linuxserver image).
On some FLAC tracks (always the same ones), playback starts normally, but after ~4–5 seconds the last second of audio starts looping indefinitely.
This issue only happens in the following scenario:
- Source: Plexamp/Plex Web
- Server: Plex on NUC via Docker
- Output: Cast to JBL speaker
- Playback mode: audio transcoded to OPUS (not by choice)
Tests performed
Playing the same FLAC track on Nvidia Shield
→ Direct Play FLAC — works fine
Casting the same FLAC file via VLC to the JBL speaker
→ Works fine
Casting via Plexamp → OPUS transcoding
→ Audio loops after ~5 seconds
Casting via Plexamp → Server transcodes to MP3 (custom profile - Chromecast.xml)
→ Works fine
All tracks are from the same album, same encoding (16-bit / 44.1 kHz FLAC).
Only certain tracks exhibit this behavior.
Relevant log extract from the failing playback
The session is always started as a transcoded stream, even though the Chromecast profile already declares FLAC as Direct Play compatible:
/music/:/transcode/universal/start
directPlay=0
directStreamAudio=1
audioCodec=opus
The server then forces OPUS transcoding:
codec:0 libopus -b:0 512k -segment_time 1
Example file properties:
02 - The Walkabout Bounce.flac
Sample rate: 44100 Hz
Channels: 2
Bit depth: 16
Codec: FLAC
What appears to be happening
Chromecast Audio never receives FLAC as Direct Play
even though the profile already contains:
<MusicProfile container="flac" codec="flac"/>
Plexamp always initiates playback with directPlay=0
which forces the server into the universal transcoder pipeline default audio transcode target = OPUS 48 kHz
With some FLAC files:
playback runs fine for ~5 seconds
then the output loops the last second indefinitely
When modifying the Chromecast profile to force music transcoding to MP3 instead of OPUS:
Playback works
But quality is reduced (no longer lossless)
This strongly suggests the issue is related to:
OPUS transcoding + Chromecast Audio / JBL Cast
triggered only with certain FLAC tracks
**Questions
Is this a known issue in the OPUS transcoding pipeline for Cast audio?
Why does Plex never attempt Direct Play FLAC to Chromecast Audio, even when the device appears capable of handling it?
Is there a recommended workaround to allow FLAC Direct Play for Cast audio ?
Thanks a lot for any help !
Chrisbati
