This is all hard work for you guys. One more exception / specific bit to cope with:
On forums home page with list of forums/categories. The NAS one has subcategories and they are not visible
try this on a new line (you might have to adapt the color value)
.Meta a {color: #333;}
edit: strike that, it is not that easy.
Wow! Even more good stuff! I’ll be rolling all these changes in when I get
to a computer
I will wait for your update. The change did not work for me and i have not bothered looking at what color is #333.
@OttoKerner said:
.ProfilePhoto, .Discussion .Author .ProfilePhoto, body.Rank-Employee .MeBox .ProfilePhoto { border-radius: 0px !important; }
I have no idea how to go about doing this and no knowledge of code. I’m hoping @vanstinator can implement square avatars for the Classic Forum for Plex
Learn it ![]()
in Chrome, click on ‘Stylish’ icon, ‘Manage Installed Styles’, ‘Edit’,
add the css instruction on to a new line, Save
Done! That was too easy to do. The square Avatars look so much nicer and not distracting at all to me now. Thanks!
Had a few minutes so I added square avatars (thanks for that bit of CSS btw, was planning on doing that at some point. I’ve also fixed some of the link colors so the child categories under NAS show. I need to go through my CSS and redo all link colors so they cascade and inherit properly.
Worked like a charm. Although I changed the radius to 5 to give it a slight rounded edge. I think the perfectly square images look odd.
Style Udpated:
Agreed, although I went with a radius of 2.
Oh, that NAS section SA2000 pointed out is going to be trouble. The subsections don’t have an Unread tag. Anyone notice this? How are you handling it?
But it is ok here - using classic forum for plex
Anyone know why only 2 of the 4 styles i have installed are showing in the selection menu (top right)?
Not that part. That looks fine under my style. I was referring to the next page when you click on NAS. The list of different categories do not have a read/unread tag. I have other categories marked in Orange if there is a new/unread comment.
But those sections don’t have the same tag so you cannot tell if there is a new/unread comment so they can only be formatted in 1 way. I’ve chosen to make it Orange for now. The forum admins will need to add in the read/unread tags for these sections to be able to be marked correctly.
Make sure that first check box “Only Enabled Styles” is off.
Very nicely done!
Only enabled styles is unticked. Similarly only edited styles - so no filters active
Is there a limit of 2 ?
definitely not. I have 5. your screenshot shows at least 5 tabs with ‘Stylish’ open. maybe they lock each other?
I’ve got 3 and they all show, so I don’t know why you only see 2.
I have closed all the Stylish tabs leaving only 1 - still the same. I will close all browser windows and reload
