Server Version#: FreeNAS-11.2-RELEASE-U1
Player Version#: 11.2-RELEASE-p9
I was turning on my server i recently moved to my new house same internet provider same ip
i checked to make sure i can still connect to the Freenas but when i try to restart or start plex this happens.
and for some odd reason the ip i use for plex is going straight to freenas??!!
Error: concurrent.futures.process._RemoteTraceback:
Traceback (most recent call last):
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 542, in start
iocage.start()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1654, in start
callback=self.callback
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 66, in __init__
self.__start_jail__()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 524, in __start_jail__
self.start_generate_resolv()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_start.py", line 842, in start_generate_resolv
shutil.copy(resolver, f"{self.path}/root/etc/resolv.conf")
File "/usr/local/lib/python3.6/shutil.py", line 242, in copy
copymode(src, dst, follow_symlinks=follow_symlinks)
File "/usr/local/lib/python3.6/shutil.py", line 144, in copymode
chmod_func(dst, stat.S_IMODE(st.st_mode))
PermissionError: [Errno 1] Operation not permitted: '/mnt/DATA/iocage/jails/plex/root/etc/resolv.conf'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1109, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1046, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1073, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1004, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 989, in run_in_executor
return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))
