fresh install freezing a lot
Hello,
After having limited success with the other XBMC builds for Raspberry Pi (openelec, raspbmc, and xbian), I was excited to learn about Rasplex today, so I put it on an SD card and loaded it up.  However, I am having a lot of trouble with it.  On the first load, I tried to go into Preferences->System, but it froze before loading the menu.  I rebooted and tried to do video calibration, but it froze during this process 3 times.  I gave up on that, and was just browsing around the menus, when out of nowhere I got vertical lines all across the screen, and the Pi became unresponsive.  I rebooted again, and decided to test out the Netflix channel.  I found a show and tried loading it - after about 15-20 seconds of waiting, it did the same vertical line thing, and again became unresponsive.
Any tips for getting this to work, or should I just wait for a future release?
Thanks!
Which Raspberry Pi version do you have? (Model, RAM size)
This is not normal behavior (at least not on 512MB versions).
Try to use a different (more powerful) power supply - it seems many issues are caused by power issues...
Try to lower the overclocking. It worked for me. Edit config.txt.
My RPi/Rasplex does not work with any form of overclocking.
I have the 512MB model, and my power supply is rated at 5V and 2.1A. Also, I didn’t overclock rasplex after installing, so unless it ships overclocked, that shouldn’t be it. Do you know what else it could be?
Please try RasPlex without network connection. It should be very fast and snappy. Try to access the settings too.
Connect to the network if everything was fine and try to access RasPlex via ssh.
 Also, I didn't overclock rasplex after installing, so unless it ships overclocked, that shouldn't be it. Do you know what else it could be?
Rasplex ships overclocked. At least it did up to version 0.1.27
This is what I use:
# default recommended values are: arm_freq | core_freq | sdram_freq | over_voltage
# no overclocking               :    700   |    250    |    400     |      0
Thanks for the info and suggestions - I'll try them when I have a minute and will report back.
Hey guys,
I'm having similar issues with the latest builds (.31 and .32). The .30 one works perfect. Was there a change in overclocking settings after .30?
+1, getting freeze during video playback, 4 mins and 15 mins into movie. Full reboot required. Other Rasplex running 1.30 seems fine, freezing one is 1.32.
Both boards are Model B 512's. Will compare the two clock configs and report back.
I am having similar issue with 1.31.  Model B 512 pi with class 10 SD card, acessing network over WiFi.  I have notice that when the freeze occurs my Edimax wifi dongle blue light will not flash but just stay on.
Been using 1.3 with good performance. I tried 1.32 today and I’m getting the vertical lines and freezing. Im back to 1.3. 512 model.
we changed almost nothing between 0.1.30 and 0.1.31 (just added some modules).
It would be great to get some logs from you since I'm unable to reproduce this.
Please use pastebin or attach the logfile (I would prefer logs from 0.1.31 since debug logging is enabled by default)
(The logfile is at /storage/.plexht/temp/plexhometheater.log)
When rasplex freezes it kills my wifi.  Does the bug log reset after I reboot?  If so I will not be able to get the report via SSH because I have to reboot.
Just use the old log after reboot: /storage/.plexht/temp/plexhometheater.old.log
OK, I'm running 0.1.36 now on default cpu, etc. settings and it seems to be running smoothly (albeit a little slow).
However, I tried to play a show on netflix, and it would not start.  The log file had the following error in it - many, many times:
12:17:15 T:2604975200  NOTICE: Resolving indirect URL:
12:17:15 T:2604975200  NOTICE: PlexDirectory::GetDirectory()
12:17:15 T:2604975200 WARNING: FillBuffer: curl failed with code 3
12:17:15 T:2604975200   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
Any idea how I can resolve that?  Thanks!
Edit: I just noticed the audio of that show was playing through my computers speakers?!?  I had to close the Plex Media Server to make it stop...
