Generate intro video markers not showing in settings
Hi, hope someone might be able to help.
I’m running my server on a 2019 shield pro, and have a lifetime plex pass. For some reason, I have never been able to turn on the skip intro feature. The option to generate intro video markers just isn’t showing when I go into library settings. It doesn’t exist.
Have tried rebooting the server, clearing cache on browser etc with no luck. Anybody else found this and have a solution? Thanks for any help!
Server Version#: 1.18.0.1913
This feature was introduced in Plex Media Server version 1.19.3.2793, so you’ll need to upgrade your server in order to use it.
https://support.plex.tv/articles/skip-content/
Or was it 1.19.3.1831?
Great, thanks. That makes sense. Can you help with how to upgrade the server on Nvidia Shield? Sorry for very basic question, I thought it would update automatically. Many thanks!
Unfortunately I don’t own a Shield, so I have no experience using it as a server. However, I believe it can be updated through the Play Store. Hopefully someone else with experience with the Shield will drop by and provide better guidance.
I found it - needs to be manually updated through the play store. Thanks a million for your help!
No problem, glad you found it. Hopefully you’ll be able to generate intro markers now.
