Generating loudness and sonic analysis constantly running
Server Version#: 4.115.2 (and the last several releases)
I run plex from QTS on a TVS473 and have been having issues with Plex constantly generating loudness data and performing sonic analysis on my music library, this has ended up causing crashes which I expect is just from the nas running at full CPU for too long.
I have just done a fresh plex install hoping that would solve the issue, and allowed plex to rescan my music library and perform fresh anaylsis. This all seemed to work fine and once it was done the anaylsis didn’t continue.
However, to allow plex to reanalyse everything quickly, I didn’t run a VM at the same time. I have now started running a VM again and the issue occurs again. The VM does run Lidarr if that looking at the music folders could be part of the problem?
If i need to share logs is there an idiots guide I could look at for this?
Just to add, it’s not Lidarr, running the VM without Lidarr and the issue still occurs. I’m running the virtualization stations beta.
