Server Version#: 1.108.1.307-dd5b87aa
<If providing server logs please do NOT turn on verbose logging, only debug Ok, I finally bit the bullet and bought Plex Pass since the price was about to jump. One of the things it says it does is skip commercials. is this only for DVR content. I have other content in my library with commercials and it isn’t skipping. It also isn’t skipping the intro or credits. I have restarted the entire server and it shows I have it. what am I doing wrong?
I think you have to put files in one of a few folders or tell the directory is that type to get it to scan. I had some windows tv files that I let plex remove commercials by converting them to a file plex knows then placing them as TV or Movies
OK, the folders were there before. I have told Plex to scan again and still no luck. Should I kill the tv show folder and rebuild it?
A) this will take time depending on the size of your library
B) Plex does some of these tasks during scheduled maintenance windows
C) You can try using the analyze function of the library to start a non-scheduled task for this
D) You can use Webtools-ng to force the two different scheduled tasks to run outside of scheduled windows.
I didn’t see it mentioned, but you need to ensure you’ve enabled ad detection for your library (or libraries) before ad detection will work. Edit the library, navigate to the Advanced tab, and find the Ad detection setting toward the bottom. Ensure it is set to “For all items.”
After that is configured, you can manually analyze items (or entire shows). Also be sure to configure the server’s Settings → [Select Server] → Library → Generate ad video markers setting to match your preferences.
I have enabled ad detection. I have analyzed the library and it shows sections as ads. I have said to skip ads automatically. It still shows the ads.
That setting needs changed on all devices, and on some (Web) I know the settings can be… odd…
For example I can never get skip intros to automatically work via the web, but when set on other players works just fine.
I have done it on the Roku app and i phone player. Still the same result.
Can you please provide the XML info (click orange link for for directions) of an episode which has gone through ad detection? (If you’re using Safari you need to enable its developer options to be able to collect the XML info.)
If it truly has commercial markers you should at the very least see the “Skip Ads” button whenever there are commercials.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
Your text didn’t paste in correctly. Please make sure to place it within a reformatted text block.
Like this.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="11" librarySectionTitle="TV Shows" librarySectionUUID="a8b67780-2cb9-41ff-95ce-4d8e52095e6d" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1741935996">
<Video ratingKey="18755" key="/library/metadata/18755" parentRatingKey="18747" grandparentRatingKey="18746" guid="plex://episode/6290e85dd0a0d01768491fdf" parentGuid="plex://season/603986ea68c8b1002d19c8cf" grandparentGuid="plex://show/5d9c09123c3f87001f35b9ca" grandparentSlug="star-wars-andor" type="episode" title="Reckoning" grandparentKey="/library/metadata/18746" parentKey="/library/metadata/18747" librarySectionTitle="TV Shows" librarySectionID="11" librarySectionKey="/library/sections/11" grandparentTitle="Star Wars: Andor" parentTitle="Season 1" contentRating="TV-14" summary="Cassian's desperation to avoid arrest leads him to a mysterious man with unknown connections." index="3" parentIndex="1" audienceRating="8.4" year="2022" thumb="/library/metadata/18755/thumb/1742390367" art="/library/metadata/18746/art/1741742603" parentThumb="/library/metadata/18747/thumb/1741742604" grandparentThumb="/library/metadata/18746/thumb/1741742603" grandparentArt="/library/metadata/18746/art/1741742603" grandparentTheme="/library/metadata/18746/theme/1741742603" duration="2636820" originallyAvailableAt="2022-09-21" addedAt="1741783781" updatedAt="1742390367" audienceRatingImage="themoviedb://image.rating" chapterSource="media">
<Media id="35014" duration="2636820" bitrate="1897" width="1280" height="720" aspectRatio="1.78" audioChannels="2" audioCodec="aac" videoCodec="h264" videoResolution="720" container="mp4" videoFrameRate="24p" optimizedForStreaming="0" audioProfile="lc" has64bitOffsets="0" videoProfile="high" hasVoiceActivity="0">
<Part accessible="1" exists="1" id="35317" key="/library/parts/35317/1741778877/file.mp4" duration="2636820" file="/Volumes/Expansion/Plex/TV Shows/Andor/Season 1/Andor - s01e03 - Reckoning.mp4" size="625299101" audioProfile="lc" container="mp4" deepAnalysisVersion="6" has64bitOffsets="0" hasThumbnail="1" optimizedForStreaming="0" requiredBandwidths="2025,2006,2000,2000,2000,2000,2000,2000" videoProfile="high">
<Stream id="64395" streamType="1" default="1" codec="h264" index="0" bitrate="1698" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" codedHeight="720" codedWidth="1280" frameRate="23.193" hasScalingMatrix="0" height="720" level="31" profile="high" refFrames="4" requiredBandwidths="1831,1813,1808,1808,1808,1808,1808,1808" scanType="progressive" streamIdentifier="1" width="1280" displayTitle="720p" extendedDisplayTitle="720p (H.264)"> </Stream>
<Stream id="64398" streamType="2" selected="1" default="1" codec="aac" index="3" channels="2" bitrate="191" audioChannelLayout="stereo" profile="lc" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="44100" streamIdentifier="4" displayTitle="Unknown (AAC Stereo)" extendedDisplayTitle="Unknown (AAC Stereo)"> </Stream>
<Stream id="64396" streamType="3" canAutoSync="0" default="1" codec="mov_text" index="1" bitrate="0" language="English" languageTag="en" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" streamIdentifier="2" displayTitle="English" extendedDisplayTitle="English (MOV_TEXT)"> </Stream>
<Stream id="64397" streamType="3" canAutoSync="0" codec="mov_text" index="2" bitrate="0" language="Spanish" languageTag="es" languageCode="spa" requiredBandwidths="1,1,1,1,1,1,1,1" streamIdentifier="3" displayTitle="Spanish" extendedDisplayTitle="Spanish (MOV_TEXT)"> </Stream>
</Part>
</Media>
<Image alt="Reckoning" type="coverPoster" url="/library/metadata/18747/thumb/1741742604"/>
<Image alt="Reckoning" type="snapshot" url="/library/metadata/18755/thumb/1742390367"/>
<Image alt="Reckoning" type="background" url="/library/metadata/18746/art/1741742603"/>
<Image alt="Reckoning" type="clearLogo" url="/library/metadata/18746/clearLogo/1741742603"/>
<UltraBlurColors topLeft="211e1c" topRight="352d2a" bottomRight="383231" bottomLeft="433f3b"/>
<Guid id="imdb://tt13847540"/>
<Guid id="tmdb://3745382"/>
<Guid id="tvdb://9285730"/>
<Rating image="imdb://image.rating" value="8.5" type="audience"/>
<Rating image="themoviedb://image.rating" value="8.4" type="audience"/>
<Director id="35899" filter="director=35899" tag="Toby Haynes" tagKey="5d776b5f594b2b001e6d7ffd" thumb="https://metadata-static.plex.tv/6/people/6852da8ee7696cc40cf8671c84141559.jpg"/>
<Writer id="18479" filter="writer=18479" tag="Tony Gilroy" tagKey="5d77682a7e9a3c0020c6b34e" thumb="https://metadata-static.plex.tv/b/people/b239765811e7f5e9453a9391367699a3.jpg"/>
<Role id="18483" filter="actor=18483" tag="Diego Luna" tagKey="5d776827eb5d26001f1dd881" role="Cassian Andor" thumb="https://metadata-static.plex.tv/6/people/66bd73d89012949e1307ed14df42b5e6.jpg"/>
<Role id="19344" filter="actor=19344" tag="Stellan Skarsgård" tagKey="5d7768255af944001f1f63e5" role="Luthen Rael" thumb="https://metadata-static.plex.tv/f/people/f230641826fbfec64eac78ff97949587.jpg"/>
<Role id="69166" filter="actor=69166" tag="Kyle Soller" tagKey="5d7768fd96b655001fdc736d" role="Syril Karn" thumb="https://metadata-static.plex.tv/7/people/7c1319be1ad0498a916667e3750c9ef5.jpg"/>
<Role id="69167" filter="actor=69167" tag="Denise Gough" tagKey="5d7768467e9a3c0020c6fe2d" role="Dedra Meero" thumb="https://metadata-static.plex.tv/1/people/134ff401c365529cb422909a8b03e506.jpg"/>
<Role id="69168" filter="actor=69168" tag="Adria Arjona" tagKey="5d776ad57a53e9001e7110d7" role="Bix Caleen" thumb="https://metadata-static.plex.tv/3/people/351600f2a2e2ca7a79a3b1ac2a3efe25.jpg"/>
<Role id="18494" filter="actor=18494" tag="Genevieve O'Reilly" tagKey="5d776828a091de001f2e6447" role="Mon Mothma" thumb="https://metadata-static.plex.tv/8/people/825e3387afad48e0396c549f550ef3cf.jpg"/>
<Role id="69169" filter="actor=69169" tag="Faye Marsay" tagKey="5d776a53ad5437001f779fbb" role="Vel Sartha" thumb="https://metadata-static.plex.tv/1/people/17f076a650d3c65046a2960c915b0dfb.jpg"/>
<Role id="27610" filter="actor=27610" tag="Anton Lesser" tagKey="5d77682a961905001eb9200e" role="Major Partagaz" thumb="https://metadata-static.plex.tv/b/people/b6d95c1cc0dca190b824e7720f69b33e.jpg"/>
<Role id="69170" filter="actor=69170" tag="Elizabeth Dulau" tagKey="5f3fcd8dcae2c60042e83087" role="Kleya Marki" thumb="https://metadata-static.plex.tv/f/people/f184b52171b96b2c731363faa7a5a34c.jpg"/>
<Role id="69171" filter="actor=69171" tag="Varada Sethu" tagKey="5d7768f07a53e9001e6dd252" role="Cinta Kaz" thumb="https://metadata-static.plex.tv/7/cc68393fae/people/7d759da5407615774af00516949be8f1.jpg"/>
<Role id="69172" filter="actor=69172" tag="Alastair Mackenzie" tagKey="62fb7cbc0310264573dc660f" role="Perrin Fertha" thumb="https://metadata-static.plex.tv/f/people/f9e37d90e875f616c4f55e333bdaf301.jpg"/>
<Role id="69173" filter="actor=69173" tag="Joplin Sibtain" tagKey="5d77691e23d5a3001f4f5e3f" role="Brasso" thumb="https://metadata-static.plex.tv/c/people/c6492d162f5dce65e0fa9e7bd2208dc8.jpg"/>
<Role id="19490" filter="actor=19490" tag="Dave Chapman" tagKey="5d7769a9594b2b001e6a6c2c" role="B2EMO (voice)" thumb="https://metadata-static.plex.tv/a/people/a1885960ab06e5a101757ebba5739715.jpg"/>
<Role id="69193" filter="actor=69193" tag="Antonio Viña" tagKey="5f406fd4bf3e560040c2f54b" role="Kassa" thumb="https://metadata-static.plex.tv/a/people/a3ef41c48bcc88c310e90142a7dbdbaf.jpg"/>
<Role id="19519" filter="actor=19519" tag="Cavin Cornwall" tagKey="5d7768ca0ea56a001e2aa444" role="Alien Grappler" thumb="https://metadata-static.plex.tv/9/people/937aecc6215b05e7e48963da2aeaccba.jpg"/>
<Role id="69177" filter="actor=69177" tag="Muhannad Bhaier" tagKey="5de4ac72d84a6c001e79460a" role="Wilmon" thumb="https://metadata-static.plex.tv/9/people/946d4240217ae97b87d4e2baa8fbe631.jpg"/>
<Role id="69178" filter="actor=69178" tag="Abhin Galeya" tagKey="5d7768a09ab54400214e8e94" role="Salman Paak" thumb="https://metadata-static.plex.tv/e/people/e3ccd788fa8eb2b423053ad5f609576d.jpg"/>
<Role id="69186" filter="actor=69186" tag="Zubin Varla" tagKey="5d77682c7228e5001f1dd6bc" role="Xanwan" thumb="https://metadata-static.plex.tv/4/people/42bb58852cc9a2ec36edf565d5bbfabd.jpg"/>
<Role id="69227" filter="actor=69227" tag="Jordan Long" tagKey="5d77682ca091de001f2e6ded" role="West-4" thumb="https://metadata-static.plex.tv/d/people/d6675e50b3ee40f9c1bee550c92906de.jpg"/>
<Role id="69228" filter="actor=69228" tag="Fraser Ayres" tagKey="5d776838eb5d26001f1e18da" role="East-1" thumb="https://metadata-static.plex.tv/d/people/d706196f2cf62ac1b90eb37f873b63d7.jpg"/>
<Role id="69229" filter="actor=69229" tag="Abraham Popoola" tagKey="5d77703596b655001fe90a7a" role="North-1" thumb="https://metadata-static.plex.tv/4/people/4931d371a6ee6963a66b5745f3f381ef.jpg"/>
<Role id="69230" filter="actor=69230" tag="Jake Lampert" tagKey="5f406955bf3e560040c24f26" role="West-3" thumb="https://metadata-static.plex.tv/6/people/63d980ac5e1db0d24827ed50b3d4d260.jpg"/>
<Role id="69231" filter="actor=69231" tag="Ron Cook" tagKey="5d776826999c64001ec2c3e6" role="Willi" thumb="https://metadata-static.plex.tv/people/5d776826999c64001ec2c3e6.jpg"/>
<Role id="69232" filter="actor=69232" tag="Richard Henderson" tagKey="5f3fc7ae52f200004148e56b" role="North-3" thumb="https://metadata-static.plex.tv/e/people/e557f104a59e7b1ce2c0d5aa104c1670.jpg"/>
<Role id="69187" filter="actor=69187" tag="Victor Perez" tagKey="5d776d7cfb0d55001f5a1a8d" role="Rashi" thumb="https://metadata-static.plex.tv/d/people/d1f1ab0105877d8cffef6af32b7e914e.jpg"/>
<Role id="69215" filter="actor=69215" tag="Gary Beadle" tagKey="5d7768468a7581001f12f8bd" role="Clem Andor" thumb="https://metadata-static.plex.tv/people/5d7768468a7581001f12f8bd.jpg"/>
<Role id="69184" filter="actor=69184" tag="Alex Ferns" tagKey="5d7768355af944001f1f9d17" role="Sergeant Linus Mosk" thumb="https://metadata-static.plex.tv/6/people/6a1569cae202b3bf63d1bb4d6f2454b1.jpg"/>
<Role id="19483" filter="actor=19483" tag="James McArdle" tagKey="5d7768b51999bc0020dce9a2" role="Timm Karlo" thumb="https://metadata-static.plex.tv/6/people/6a7009bd88f216d1daabfea5a31c12b6.jpg"/>
<Role id="69192" filter="actor=69192" tag="Fiona Shaw" tagKey="5d7768278718ba001e311e4c" role="Maarva Andor" thumb="https://metadata-static.plex.tv/1/people/19d3cf39bfb07b8c343ac48e07db1573.jpg"/>
<Producer id="69302" filter="producer=69302" tag="Kate Hazell" tagKey="5e1647f627d563003ed6177e"/>
<Producer id="18656" filter="producer=18656" tag="Kathleen Kennedy" tagKey="5d7768264de0ee001fcc851e" thumb="https://metadata-static.plex.tv/people/5d7768264de0ee001fcc851e.jpg"/>
<Producer id="69303" filter="producer=69303" tag="David Meanti" tagKey="5f3fc423fea1a1003f967d1c" thumb="https://image.tmdb.org/t/p/original/i8r3lgOTUqyfnmzrrd4k42rvkG9.jpg"/>
<Chapter id="61507" filter="thumb=61507" tag="Video" index="1" startTimeOffset="0" endTimeOffset="9546" thumb="/library/media/35014/chapterImages/1"/>
<Chapter id="61508" filter="thumb=61508" tag="Advertisement" index="2" startTimeOffset="9546" endTimeOffset="45887" thumb="/library/media/35014/chapterImages/2"/>
<Chapter id="61507" filter="thumb=61507" tag="Video" index="3" startTimeOffset="45887" endTimeOffset="681736" thumb="/library/media/35014/chapterImages/3"/>
<Chapter id="61508" filter="thumb=61508" tag="Advertisement" index="4" startTimeOffset="681736" endTimeOffset="772204" thumb="/library/media/35014/chapterImages/4"/>
<Chapter id="61507" filter="thumb=61507" tag="Video" index="5" startTimeOffset="772204" endTimeOffset="1653520" thumb="/library/media/35014/chapterImages/5"/>
<Chapter id="61508" filter="thumb=61508" tag="Advertisement" index="6" startTimeOffset="1653520" endTimeOffset="1728880" thumb="/library/media/35014/chapterImages/6"/>
<Chapter id="61507" filter="thumb=61507" tag="Video" index="7" startTimeOffset="1728880" endTimeOffset="2636780" thumb="/library/media/35014/chapterImages/7"/>
<Marker final="1" id="69484" type="credits" startTimeOffset="2413138" endTimeOffset="2636820">
<Attributes id="69484" version="4"/>
</Marker>
<Marker id="69484" type="intro" startTimeOffset="118105" endTimeOffset="149393">
<Attributes id="69484"/>
</Marker>
<Extras size="0"> </Extras>
<Related> </Related>
</Video>
</MediaContainer>
Thanks. Unfortunately, this particular file has no commercial markers. If there were, they’d be in this section with the credit and intro markers:
</Marker>
</Marker>
So it either hasn’t been analyzed yet or has no commercials (or the detector wasn’t able to find any). For reference, here’s what something with commercial markers will look like:
<Marker id="1709" type="commercial" startTimeOffset="0" endTimeOffset="8580">
<Attributes id="1709"/>
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="367270" endTimeOffset="438200">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="891590" endTimeOffset="921720">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="1908740" endTimeOffset="2089620">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="2396590" endTimeOffset="2572040">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="3404370" endTimeOffset="3495630">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="3549350" endTimeOffset="3599330">
</Marker>
<Marker id="1709" type="intro" startTimeOffset="268274" endTimeOffset="364928">
</Marker>
Do you have another you’d like to have a look at?
