GitHub Reference to Qt - what does it mean?
The issue that I reported in May, is still not fixed, but there has been some movement in Github, but I don’t understand what it means. Does anyone know?
It references my initial post from May which is here:
What is Qt, and what is a future cycle, and when will it happen, are the questions that I have.
Thanks!
Means that Plex will start working on it, when the QT libraries has their issues fixed
Nobody knows. Plex does not control 3.Party libraries/frameworks, like Qt, nor do they ever hand out timelines
Okay, thanks for the reply. I did google Qt and the explanation makes no sense to me. Is it correct to say that Qt is some software that is designed / managed by a third party (like the mpv engine) and is used within Plex Media Player?
If so, did the version of Qt that is used within PMP change around May time which is when Sync Mode: display broke?
Yes
Sadly no idea, since I’m not a PMP Ninja
It looks like the Qt version is visible in the top left hand corner of the screen in PMP when pressing i to get the overlay stats up.
In the version 2.10 where display mode:sync was not broken, it shows version 5.9.0, whereas in the latest version of PMP it shows version 5.9.5.
From the github post, the latest version is 5.12.
So… fingers crossed that might fix things.
Maybe, a nice Christmas bonus?!
