does anybody know how to or where to change the code so that when I enter my film library in plex connect it will go directly to all films rather than the deck?
I can access the deck on the home screen thanks to open pled so when I go to film library I'd prefer to access all films directly.
It's only a small thing but an unnecessary button press every single time.
many thanks in advance
dan
ATV 3
Mavericks 10.9.4
Latest OpenPlex
roidy
September 16, 2014, 4:37pm
2
Sure, edit the following file:- assets/templates/MovieSectionTopLevel.xml Change line 9 from:- to:-
to:-
Amazing, thanks you.
I am using OpenPlex with cyberghost theme so it initially didn't work but I found the corresponding file in his code and it now works great!
Do you know where in the code I can turn on or off menu bar icons.
In my current theme I see:
Library
Playlists
Channels
Shared Libraries
Search
Settings
I only need Library Channels and Settings in my set up, do you know if this code would be plexconnect of my template?
I tried to change it in ATVSettings.cfg but that had no effect
Library
Playlists
Channels
Shared Libraries
Search
Settings
Managed to find it in my template....
....there may be hope for me as a coder yet!
system
Closed
December 21, 2019, 3:07am
5
